Guys,
in the process of working on my floors, i cleaned the bottom and top side of the tunnel, just in front of the shifter console. Automatic in my case, it is mounted with 3 screws using speednuts on the body.
I noticed that the large semi round opening is all warped with random 'hills' and 'valleys', and 3 hairline cracks are coming out of one of the holes for the speednuts. See pics.
The deformations are strange because the matching surface of the shifter console (automatic in my case) is fully flat. Thus i expect the body to be flat, or at least symetric.
I doubt the cracks have to do with me removing the sills on one side, as cracks grow over time. Bending or buckling a car just gives you folds, not cracks.
Even more strange is a weld that is located in the groove for the wiring harness that runs down the right side of the tunnel to the floor. The weld is very factory looking, as it had the original interior paint, glue and isolation still stuck on top of it. But this weld does not connect metal structures, it can only be laid down as a repair. Were the factory pressings already showing tears during production? That would be strange...
What is going on here? is this area prone to buckling? Does it flex due to the transission casing being mounted roughly 30cm / 1 foot below it?
Attached also a pic of a reinforcement that I made up , which I am currently debating to weld to the body from the underside. (which is a nice insight into my mind; first make it then ponder wether it would be a good thing to do...)
question 2. Is this area the same for stick shifts; hole position, 3D curvatue / shape? In other words, If i weld my reinforcement into the body, am I then creating an obstruction for a future Auto to Manual conversion?
Picture "webimage" shows a pic that i just found with google. Here by coincedence the same type of cracks can be seen .
Erik.
Erik.
