maybe helpful
From an E28, but would help in identification.
Cut and paste into a spreadsheet, then cross reference. Good luck.
Steering assembly
http://www.realoem.com/bmw/showparts.do?.....32&hg=32&fg=25
Center tie rod (1 per car)-32211129014
Tie rod (2 per car)-32211135666
Idler arm (1 per car)-32211136450
Pitman arm (1 per car)-32211134277
Front subframe/control arm assembly
http://www.realoem.com/bmw/showparts.do?.....13&hg=31&fg=05
Lower control arm driver side (1 per car)-31121139991
Lower control arm passenger side (1 per car)-31121139992
Upper control arm driver side (1 per car)-31121132353B
Upper control arm passenger side (1 per car)-31121132354B
(upgrade) Upper control arm driver side with milled 750 bushing (1 per car)-31121132353P
(upgrade) Upper control arm passenger side with milled 750 bushing (1 per car)-31121132354P
MacPherson strut type assembly
http://www.realoem.com/bmw/showparts.do?.....83&hg=31&fg=10
Strut mount (2 per car)-31331139452
Upper spring pad (2 per car)-31331128523
Lower spring pad (2 per car)-31331124322
Front sway bar/anti-roll bar assembly
http://www.realoem.com/bmw/showparts.do?.....36&hg=31&fg=10
Sway bar end link (2 per car)-31351134582
(size 1) Sway bar bushing 19mm (2 per car)-31351127390
(size 2) Sway bar bushing 21mm (2 per car)-31352225419
Rear coilover type assembly
http://www.realoem.com/bmw/showparts.do?.....52&hg=33&fg=45
Upper spring pad (2 per car)-33521124507
Lower spring pad (2 per car)-33521124572
Shock mount (2 per car)-33521126680
Shock mount gasket (2 per car)-33521118480
Rear sway bar/anti-roll bar assembly
http://www.realoem.com/bmw/showparts.do?.....78&hg=33&fg=45
Sway bar endlink (2 per car)-33551126932
Sway bar bushing 15.5mm (2 per car)-33551129225
Rear subframe/trailing arm aseembly
http://www.realoem.com/bmw/showparts.do?.....04&hg=33&fg=30
Subframe bushings (2 per car)-33311130488
(optional) Subframe heavy duty bushings (2 per car)-33311130488M
Pitmain arm bearings (2 per car)-33321126476
Trailing arm bushing (4 per car)-33329061946
(optional) Trailing arm eccentric bushing (4 per car)-33329058824
The W&N bolt/ fastener kit sounds great- all new cad. The other thing is sway bar- uerathane and new end links.
