As some of you know I have an old Jag (I call the condition pre-restoration).
I installed a spare/new motor plus a wideband AF sensor, and am tuning the carbs by adjusting the needle profiles (SU's use a tapered needle where length along the needle correspond to intake airflow rates). Simple to tune because you only change one thing. But not possible to fully optimize like a DCOE.
Without modification but with new needles/jets here is where I am.
IDLE: 14.5 to 1
Light throttle cruise: 13.4 to 13.7 depending on rpm. Above 3500rpm it drops to around 13:1.
Medium throttle: 13.3 to about 13.5 to 1
Wide open throttle: 13:1 below 2000rpm gradually richening up to 12.4 to 1 above 4000rpm redline is 5500rpm).
Previously with the original 60 year old needles it was pretty much the opposite of this (14.5 at WOT and 12.5 to 1 at idle). Plugs would foul up around town, PITA.
What would you guys focus on changing first and what target AF ratios would you go for?
Should I go much leaner at idle?
Is 13.5 too rich when I'm cruising down the highway at 85mph?
John
IDLE: 14.5 to 1
John
