thehackmechanic
My 3.0 is showing more of a gap above the tops of the tires than I'd prefer. What, exactly, is the argument against cutting a coil off the springs? 2002 folks do it all the time. I read that the issue is that the spring won't sit as neatly square in the perch, but, again, how is this different from cutting springs on a 2002? This is a sedately-driven car; I'm not going to be catching air time in it. It currently has KYBs in it, though I'm thinking of ponying up for Bilstein HDs. I have an old set of springs from a parts car that I can cut. I am aware of the issue of lowering possibly causing rubbing problems with the staggered Alpinas, but that issue persists whether I use new lowering springs or cut a coil off existing ones.
