What is the BMW partno. for front fender rubber seal?
BMW3.0CSi
The Netherlands
Hi All,
I have a question about the rubber seal that is placed between the front fender and the nose section. (see picture with the red line). Is it correct that this is part number 41 13 1 817 098 ?? Or is this number for the small seal between the front bumper and the fender?
Is the rubber seal between the nose section and fender actually still available from BMW, because I think that it isn't even mentioned on the exploded views if I'm right?
Thank you!Rinke
Hi Rinke,
should be the right one and apparently available. I just googled the part number and ended up for instance there:
http://parts.bmwofsouthatlanta.com/showAssembly.aspx?ukey_product=1297347&ukey_assembly=252844
It's not that obvious if the price is per piece or per metre. Anyway in both cases again pretty ridiculous high, like every rubber and a lot of other parts on this bloody car.
I was searching the same seal receintly but decided to let it out since it might be a better choice to mount the lokari fender liners. In that scenario you might not need these seals at all
cheers
Ingo
Hi Ingo,
Thank you for your reply. Ok, so this is the rubber seal I need. I have heard about the Lokari's, might be an option to, but I prefer to keep the rubber seal in. I think it prevents getting mud in the nose section. It is indeed expensive, but if that was the biggest problem I had to buy another car.. ;)
Another question (in general), does anyone know if these are rubber seals are also supplied by other shops?
Regards
