After some effort I got the window motor and crank assembly out of the driver side door. I have the 2 wire motor with the black plastic case and it works fine on the bench and the electrical bits in the motor look great - clean as a whistle.
I would like to clean and relub the plastic wheel/worm drive assembly. I do not see exactly how to take the plastic wheel out, and may just try to clean the old lube up as well as possible in place and then put new grease in.
What sort of stuff should I use?
Mark
'73 3.0CS
Mark
'73 3.0CS
