MMercury
- Messages
- 481
- Reaction score
- 6
This topic may have been previously discussed, but I did not see anything on it via the search function.
I was replacing front rotors and when I got to the point of repacking the wheel bearings I couldn't seem to locate any of the seemingly tens of wheel bearing grease containers I usually trip over. If it matters, I have been using sythetics supposedly designated for that purpose. In looking around for the grease, I discovered a large cache of CV joint moly lube and began to wonder whether it couldn't be used for wheel bearing lube too.
Let me explain that I found the wheel bearing grease and used it, but I am still wondering. Common sense tells me that wheel bearings fitted next to outboard disk brakes are probably exposed to higher operating temperatures than CV joints and the bearing loads are probably greater for wheel bearings too. But cv joints are no slouches when it comes to loads - hence the requirement of molydenum extreme pressure lubricant.
So why aren't the two grease types interchangable or, conversely, why is that no recommends using wheel bearing grease to repack cv joints or CV joint lube for wheel bearings?
Thank you in advance.
