Tow loops
It's my understanding (this is hearsay) that the loop on the spare tire well was used to secure the car during cross-Atlantic shipping. I expect the two front loops, at the front "frame" rails, were used similarly.
I also have had a front loop break off during towing, and it's no fun. The geometry of the tow changes quite a bit, quite suddenly. Of course it only happens when coming around a very sharp bend at an 18% grade...
Even if it' s only a rollilng chassis, I wouldn't use the rear loop. Jack it up, support it, and get a tow rope or sling around something meant to take the thrust of the wheels. I'll continue to use the front loops, mostly because they are fairly securely welded to the subframe, won't cause the sling to rub on the body, and there's little else (easily) available.
but you've been warned
