Honolulu
Hello all:
My original copper radiator is losing fins, and leaking a bit at the tank seam on one side. About five years ago I watched the old pro remove the tank and rod it out, then resolder everything back together. I've had at re-soldering the tank seam a couple times but am thinking that maybe it's the end for this rad.
Latest adventure was overheating on the way home with the daughter. I was able to pull off the freeway, refill and bleed. Thanks to somebody (not home at the time) whose garden hose I used. Your hose helped me considerably. It's still there.
Some years back, I replaced a plastic tank radiator (spare me the commentary on those) in my E28 533i, for $160. did it a year ago on the wife's '98 MB C280. The 533i got a new radiator for $160. Compare to $500 or so to recore the copper, if it can be found. Remember that I'm in Hawaii, so add Zone 8 shipping from anywhere.
The original radiator, while and when it holds coolant, is just fine with the new tstat and new water pump. I don't run AC, and drive mainly to/from work. Honolulu temps average in the mid to upper 80s, and very seldom go into the low 90s. Sorry for those whose climates are not so moderate.
I can get wholesale prices locally through a friend in the business, but I've searched the tech archive for which later radiator will fit. Open to suggestions... is it one from an E12, E28, E32 or ....? I anticipate some creativity with the hoses may be needed.
TIA
Honolulu
TIA
Honolulu
