Just curious about this... It looks like there is a small piece of rubber hose right on the nipple of the fluid reservoir and then a solid tube from there on. Why not continue that rubber hose and use the same type of brake hose as the one going to the brake MC? It is a simple gravity feed and there is not pressure in the line at that point and not much heat on that side of the motor...
