I installed a wideband gauge as the next step in trying to get my triple webers set up. My numbers are from what I've read on the internet, atrocious.
Lean best idle = 11.7
Hard acceleration = 11.5-12.5
WOT = 12
Cruise at 3500 rpm = 12.5
Over run = 13.5
I can't get the idle above 11.7, I have different idle jets and it seems the engine simply likes this number no matter what. Idles smoothly.
Here are my current specs:
40DCOE32 carb
4.5 aux venturi
32mm choke
125 main jet
F9 emulsion tube
200 air jet
50F9 idle jet
40 pump jet
60 pump bleed
200 float needle valve
Timing is 14BTC at idle and 34BTC all in.
2 things - I have new 32mm chokes because I was missing one when I bought them and the size of the exising ones was unidentifiable. Should I be running 34mm chokes for these jets? Would larger chokes lean up the overall powerband? Although very rich, the readings are pretty consistent throughout the rev range. Are smaller chokes sucking more fuel mixture in as well as sooner?
It does not like leaner idle jets, I tried F8 and it spit at me.
Should I try a smaller main? Seems like I already have a wide diparity between the 125 main and the 200 air jets.
Runs well, but rich obviously, with no smoke out the exhaust. No bogs or transitional issues - revs nicely.
Suggestions?
WOT = 12
Over run = 13.5
40DCOE32 carb
4.5 aux venturi
32mm choke
125 main jet
F9 emulsion tube
200 air jet
50F9 idle jet
40 pump jet
60 pump bleed
Suggestions?
