runner
Finally it's driving time around here. But, I need to fix/ maintain a couple items.
1. My drivers side door armrest pull for closing door has pulled loose(the screw) from the card. I have always tried to close door from inside by just holding on to the vent window post- slightly cracked- to avoid this. But, somehow it still happened over the years.
2. On the same drivers door, the window works and goes down, but about 3/4 down starts to "scrap a bit" , seems to be grabbing, so I don't want to go further and mess it up. Should be lubricated etc?
So, on the above, I need directions again, on how to put the door card without braking clips and also where/how to take off handle if needed. Just playing it safe.
3. Rear passenger window has suddenly stopped working. It is up, but does nothing when I use the switch. No noise either. My 1st thought is to take the center consult window switch out and clean contacts. If so, again, directions on removing before I break anything.
John
John
