window issue
TRIPPFONTAINE
Melbourne, Australia
My driver's side front window stopped opening/closing. The motor still works but when I opened up door, it appears that the sliding arm has come loose from the track rail attached to the glass. The clips and rubber washers that holds the arm place are missing (old age I guess) and are not sitting at the bottom of the door.
The manual doesn't give any clear detail on how these washers are held in place on both sides of the rail... any suggestions as to how this is done and if there are relevant part #s?
The arm end should just slip in the groove end. depending upon where the arm is you may have to wind it down a bit and pull up the glass. Or pull the bolts on the motor to freely place the arm end back.
