in an effort to speed up my windows, following up on the excellent posts by Stevehose, Jmackro + DeQuincey on this subject ... i have already regreased my rear windows and gearboxes and am now ready to provide cleaner power to all of the motors (i will clean + regrease my front regulators + gearboxes while i do the rewiring. to better understand the wiring, i have put it into the format of the enlarged 2800cs wiring diagram for comfort equipment in the blue books. the wiring for a 3.0cs might be slightly different (i haven't looked)
i will be using hella 965400001 SPST (4 pin relays) - 3.77 each from summit racing, mounted in hella h84989011 sockets. 1.11 each from summit racing. I will be using 12 ga wire from the battery to the 30 pin side of the relays and 14 ga wire from the relays to the motors. i will leave the existing wire to the switches as little power will flow down those wires. i will leave the wiring between the motors and the terminal connectors - all rewiring will be done on the switch side of the terminals.
if you see anything that looks wrong with this wiring approach, please let me know. any other advice is also welcomed. otherwise i will keep you posted on the success achieved.
