- Messages
- 292
- Reaction score
- 75
EDIT: Disregard most of the following, I didn't realize the difference between having a diode on the control circuit of the relay vs. the load circuit. The concept is identical, but applied in a different location.
I found many mentions of adding relays to the power windows with good results, so I decided to go for it. I found the diagram below in multiple threads. I wondered about the diodes, so I did some research. I learned a couple of things, 1) there's no need to add them separately since you can easily buy relays with diodes already in them (easily online anyway, not necessarily at autozone). 2) I don't think they're useful in this case. They are used to protect a digital circuit that is used to switch the relay, but in this case the switching is done by a very robust mechanical means, so there's no need for protection. This paper I found from TE Connectivity (one of the major manufacturers of relays) discourages their use when they aren't needed to protect a sensitive circuit. So I ordered standard relays for everything. About $3.50 each from Waytech Wire.
http://www.te.com/commerce/Document...v&DocNm=13C3264_AppNote&DocType=CS&DocLang=EN
