Winsdshield Replacement
Andre: if you are handy and patient, you can do the windshield installations yourself. It helps to have a faithful assistant, but I have done it myself, twice, with no problems. My car never sees moisture, so I did not use sealant anywhere.
Helps to have good, flexible gaskets. Definitely put the chrome strips in before replacing the glass. Use nylon string (slippery) and take your time placing the windshields on the car, getting them centered as best you can, and gently wiggle them all around the perimeter to get a good initial fit. Then get inside and carefully work the string, working a few inches on one side, then the other and so on until done. It'll take a couple of hours, so give yourself time. When done, have a good India Pale Ale. Good luck.
Bill 74 3.0CS
