Wipers and light stalk switch
shanon
NorCal
Gruppe:
Think I buggered my wiper/light stalk being ham fisted when 'acclimating' to the E3 on an evening drive. My E9 set up is modified and very 'different'.
Now I cant turn off the wipers or turn on high beams...argh.
Any advise on a fix or locating a replacement appreciated.
Are they the same 'stalk' from an E9? (wondering if I may have one stashed somewhere?!)
TIA
-s
that's a good question. i know the part numbers are different but i have no idea if its just the wiring that is different or just the length / angle of the actual stalk. i would think the wiring was basically the same as i remember (could be off) the configuration is the same (right side turn on pre '74 and left side turn on the '74).
what is the model year of your e3? i would recommend giving a shout to Al Taylor as he has always had a lot of e3 stuff
on e9 the connector is different between pre '74 and 74+ ... also a different color. the early ones are translucent white ... i have seen the late ones as black
i just looked on w+n, they have the 74+ switch for 170 euro - 61311360977
they also have the turn signal switch for 74+ for 150 euro. - 61311363638
i just looked and they have the same part number for both e3 + e9. real oem, confirms this for the 74+ for both models (e3 + e9), but there are different part numbers listed in the individual listings.
the e3 turn signal switch on the pre '74 is not listed
the e3 turn signal switch for 74+ is 61311355285
the e3 dip switch for pre '74 is 61311351070
the e3 dip switch for 74+ is 61311355285
the e9 turn signal switch on the pre '74 is 61311355322, but that is only for the coupe
the e9 dip switch on the pre '74 is 61311351856, but that is only for the coupe
the e9 dip switch on the 74+ is 61311363638 (this part supercedes - 61311357005)
