Nylon LoopWatching with interest! What interior color is that?
I do have a hand held steamer that I have used on the headliner and will try it on the carpet. I wasn't sure if it would work on carpet and will try it. ThanksNice If you use a small hand held steamer, and a hand roller, you will be able to get all those wrinkles out
Thanks, Rick
The piece behind the shifter isn't glued down and should be smooth. I may have to build up some areas on the driver side tunnel to smooth it out. ThanksCan you build up what's underneath, that's what I did.
That’s the colour in my car. I would like to replace the tired front driver mat and trunk. Where can I get them. Many thanks.Nylon Loop
on pieces that aren't glued down, like the tranny tunnel piece - perhaps try a little velcro on the either side of the tunnel to allow pulling a little tension. if you glue the tranny tunnel carpet you will likely destroy it if you have to remove it. that happened to me as the PO glued that piece down. when my interior goes back together i thought i would give this a try.The piece behind the shifter isn't glued down and should be smooth. I may have to build up some areas on the driver side tunnel to smooth it out. Thanks
Thanks Dan.I know World Upholstery offers the trunk carpet and I bet if you contact them they would sell the driver floor carpet.
They will send you samples of the carpet so you can make sure it matches.
Carpet Sets (Interior and Trunk) for BMW CS Coupes (New Class, E9) from World Upholstery & Trim
Interior and Trunk Carpet Sets for BMW CS Coupes (New Class, E9). World Upholstery & Trim manufactures authentic reproductions of the original carpet covers to replace the old carpet in your BMW whether it is cut and bound or molded. Models include 2000C, 2000CS, 2800CS...worlduph.com
Scotton pieces that aren't glued down, like the tranny tunnel piece - perhaps try a little velcro on the either side of the tunnel to allow pulling a little tension. if you glue the tranny tunnel carpet you will likely destroy it if you have to remove it. that happened to me as the PO glued that piece down. when my interior goes back together i thought i would give this a try.
It’s looking great I tried to get just the driver side floor mat, but they will only sell full sets. They are sending a German carpet sample. Yours look so great that I’m tempted to replace my original set. They haven’t quoted a price.Thanks for all the comments. More progress on the carpet. Not all areas have been glued. I am looking at vecro to keep the floor pieces from sliding. I am not sure I will use the "U" shaped pieces since I used vinyl over the seat track areas. I still need to work on the dog legs with the trim around the seat track releases. I don't care for the carpet to carpet area behind the tunnel to the back wall. I think I can work it some to make it look better and that area is not glued.
Thanks! You might try taking your floor mat to an auto upholstery shop and see if they can match it and/or buy some coco mats.It’s looking great I tried to get just the driver side floor mat, but they will only sell full sets. They are sending a German carpet sample. Yours look so great that I’m tempted to replace my original set. They haven’t quoted a price.
Great idea. While I am the original owner, I’m not trying to get to the concourse level.Thanks! You might try taking your floor mat to an auto upholstery shop and see if they can match it and/or buy some coco mats.
