WTB: E9 telescopic parts
teahead
aka "Rob"
Tacoma, WA, USA
Need:
- lower finish panel:
8785c853-d53e-4006-83f1-1a7fd100fa54-jpeg.37436
- booster/pedal mount:
20171215_140046-jpg.37375
- And black plastic cover and column rods/u-joints (circled)
Rob, i have the steering column and the booster / pedal mount. don't want to take the rod off of the remainder of the column was planning to keep them as spares ... but doubtful i will ever use them. i have the other two pieces that i won't sell at this time. the under dash panel is very hard to find in decent shape. the plastic panel was used on the late e12 and i believe the e23 ... maybe the e24, so it shouldn't be too hard to find.
I believe E3 upper/lower plastic panels (not the vinyl-covered under dash panel w/the switch holes) are same as E9.
the lower plastic panel is part number
32311152991 or 32311111929 (original number)
this fit the e3 / e9 / e23 / e26 (m1). your best chance is to find it on an e23 as the e3 + e9 only had them as of 10/73 ... and e26 search would not prove worthwhile
i have a spare one but it was cracked and repaired by PO. not great but it is better than not having one
i was under the impression that the late e12's had this feature but real oem didn't list it with the part number ... its been a really long time since i sold my e12. realoem lists the e12 part as 32311152990 ... which is 1 number away from the final e9 part number (32311152991). would be great to know if they were interchangeable.
I think the shaft on the left is E3. Can you measure the total length, including the u-joint on that one? Thanks.
