WTB: Early e9 turn signal stalk, brights/dimmer stalk, and rear defrost switch/button
sreams
Sacramento, CA
My '72 3.0cs has the turn signal stalk on the right side of the steering wheel. It works, but often must be pressed a bit further (and held there) in order to make contact and activate the turn signals. I suppose it may be repairable if I take it apart.
Also, a friend (after apparently forgetting what I told him) grabbed the brights switch thinking it was the turn signal and broke it. It is now badly cracked internally and a sloppy mess. Looking for a replacement.
Finally, a few days ago, the rear defrost button stopped working altogether.
I'm looking for any/all of these things if anybody has them lying about. Thanks!
-Scott
Scott, I have all 3, just took photos of the column switches but am on the road, email me at [email protected] and if you can send phot's of yours so I can see if I have a match, from memory I have 2 different one has black plastic wire plug connector that is rectangular, the other has a white plastic that is square...
|Thanks
Alonzo Taylor
