If you are replacing it because of the broken stud, it can be cut off, drilled, and tapped (there is enough material). Then a stud or cut off bolt can thread in.Hi,
I'm looking to buy the driver side rear bumper horn rubber piece in good to excellent condition, I believe this is the part no. 51121810973
Hopefully available here in the states, Thanks in advance
Best Regards
Thanks Tom, I saw that, I wanted a good used one to match the patina on the pass. side,![]()
Gummipuffer Stossstangenhorn hinten BMW Baureihe E9 2,5 -3,0 CSi CSL
Gummipuffer für Horn Stossstange hinten BMW Baureihe E9 2,5 CS 2800 CS 3,0 CS CA CSi CSL links oder rechts verwendbar, pro Fahrzeug werden…shopware.bmw-oldtimerteile.de
I'm missing the left side, The one on the picture it's a Pass. side,If you are replacing it because of the broken stud, it can be cut off, drilled, and tapped (there is enough material). Then a stud or cut off bolt can thread in.
Thanks Alvaro for the link!
