WTB: ignition switch (electric section) & air filter adv
curtian4
Washington, DC
I recently purchased a '70 2800CS and I'm looking for the electric section of the ignition switch. Anyone have any suggestions where I might find one?
Also, the car has the 40DCOE triple Webers and I'm looking for air filter assemblies that are short enough to fit between the carbs and the brake booster. Any suggestions on that would be welcome as well. The shortest I've found online were Redlines (at 1 5/8" tall), but I'm curious if anyone uses the RAMFLO's which are 2" but encased in a rounded wired mesh (and if the rounded mesh gives enough clearance).
Thanks,
Alex
shanon
NorCal
Give Pierce Manifolds (dot com) a jingle, they have these new flat mesh filters that might work for you. They were tested on a dyno and flowed very well compared to some others out there.
-HTH
shanon
Bill Riblett
(deceased)
Side draft air filters
Ramflows fit fine. The only drawback that I have found is that the filter elements are foam and seem to disintegrate after several years.
