WTB Ignition switch for 73 3.0cs
John-T
Los Angeles
Looking for an ignition switch for a 1973 3.0CS, new or one in good working condition please.
I believe part number is 61321355148.
Thank you in advance.
John
On your old switch, what is the orientation of the round locating pin to the tab for the tiny screw?
For reference call pin on posted picture at 9 o'clock and tab at 12 o'clock. The other style switch has the pin closer to 7 o'clock.
If you remove a switch with no pin, then likely the first type has been "adapted" to function. Not really sure if doing that reduces the lifespan of the switch by allowing more movement/not holding switch as tightly in position and putting load on screw.
