WTB Jetronic parts
Jasper
Copenhagen
Hello all
I’m looking for some D-Jet parts as I’m restoring the system on a ‘73 CSI.
  • Throttle return spring, 13541261710. I only have one, and it doesn’t always close the throttle by it self.
  • Jetronic main relay. At some point in time it has been exchanged with a more modern standard 87a changeover relay.
  • Relay socket/connector for the main relay. I’m making a new harness, and that’s the only part I’m missing. It’s not the one for the cold start relay.
That’s about it. Let me know if you have any of the items and want to part with them.
/Jasper
there are four springs used in throttle linkage-
have you checked the other two at gas pedal and bell crank?
sounds like a different issue-
Maybe I need to add to the list of parts missing, but the spring I need right now is one of the two sitting perched atop the throttle body.
/Jasper
you want new or used springs?
where are you located?
Hello, Don.
An old one will do just fine, as It’ll match the other one.
I’m in Denmark, continental Europe’s cowlick. :) You’d think these parts, spring at least, would be relatively easy to come by on this side of the pond, but no.
/Jasper
Sent you main relay info. Act fast.
I have the main relay plug and springs.
Hello, Don.
/Jasper
Same applies to trigger points and throttle switches...
