Upgraded pulleys on my 73 CS to move the power steering pulley from the water pump down to the vibration damper. All is good except I have the earlier power steering pump brackets which are for vertical adjustment not the horizontal adjustment now needed. Gives me very little tightening ability and only one belt on the planet from DAYCO will fit.
Looking for the second version set of brackets from production date 10/73 up so likely from a 74. With these brackets I can use the 10 x 888 belt and have a wider adjustment.
The picture shows clearly the horizontal slots on brackets # 1 and # 10 which is what I need. Brackets # 5 and # 9 are the older version. Both will fit on the mounting plate # 7 and fit the original pump.
Oddly there are twin part numbers for the later brackets I need but only the small rear one is still available.
FRONT 32-41-1-258-133 / 32-41-1-276-638
REAR 32-41-1-258-134 / 32-41-1-265-846
Anyone have or know where I can buy the set I need?
Paul
Paul
