WTB: trim pieces under window switches
Vbigdog
Marblehead, Massachusetts
Looking for NLA new or good used brushed (aluminum?) trim pieces with square holes under the window switches. Realoem part number: 51161810955
Suggestions welcome.
If others need the same trim, will contact a local fabricator and make a batch.
ae
you could make them easily and
wire brush the surface i made one to match mine
i cut a hole and filed sQUARE
Vbigdog. These may help, or may not. I will disassemble, clean and assess condition. Busy now. Will take more pics asap.
Best, Peter.
Best, Peter.
Hi Peter,
Mine look about the same. A bit of corrosion under & around the switch bezels. I think I'll have a go at fabricating a set and send out for plating.
Thank you!
Tom
I bought the left side new four years ago. Penske shows a price of $43 each but Tomkinson shows no availability. Pricey but wouldn't hurt to see if truly available.
Chris,
I'm feeling adventurous, and just bought some 0.05 Aluminum sheet. Will surface solder some threaded studs & nut on the back, and likely send to a chrome plate shop with some other pieces for a brushed finish.
...famous last words..." it doesn't look that tough"
https://www.onlinemetals.com/merchant.cfm?pid=12658&step=4&showunits=inches&id=916&top_cat=60
i think i bought Chris' old trims a few years ago. i will look to see if i still have the spare set. i know i have a spare shifter console that has them on it.
