WTB: Wiper Stalk 1973 3.0csl
db5times
New Member
United kingdom
nedrepsa
U.K.
Hello.
I have one of these which is part number 61 31 1 351852, it is used and as far as I know functions correctly although as I no longer have an e9 am unable to test.
The mechanism to cancel the indicator works correctly.
If this is of interest let me know, I am located in U.K.
Regards
Alan
db5times
New Member
United kingdom
Hello.
Regards
Alan
Hi Alan thanks for the reply. ill need to check that part number as its different to mine. what price you looking for? have you any pics?
nedrepsa
U.K.
Dave.
The part number is not the number on the switch.
I am open to a reasonable offer bearing in mind that these are unobtainable from either BMW or W and N.
Sorry do not have any photos as I do not own a smartphone.
We are in Wiltshire if you would like to test it first or my wife is travelling to Wimbledon tennis next week if that is your area.
the moulded plug with 9 pins is the thing you are looking for and that is what this switch has
bluecoupe30!
These signal switches have been associated with several part numbers. There is a number on the alloy body of the switch, then often a number printed on a white tag somewhere on the wiring. From what I can tell, the white square plug switches fit earlier cars, at least up to 1973. I believe the '74s had a black, rectangular plug as a connection. If stalk stays in position when moved up or down, it is likely not worn out and worth a try, in my opinion. They are getting difficult to find.
db5times
New Member
United kingdom
Dave.
Hi Alan. We are based in Chester so bit far away from you. I'm unsure what a reasonable offer would be if you can give me a price i can then have a think.
Many thanks
