not mine no affliliation...
http://bringatrailer.com/2009/01/05/restored-upgraded-optioned-1972-bmw-30csi/
michael said:not mine no affliliation...
acat2002 said:Assuming the car has been properly built, it has all the right bits and looks nice. I'd like to know who did the conversion before getting too giddy.
TodB said:Ah, Mr. Chicane with the quick (and negative) reply. Right on cue. Michael meant BAT as in Bring A Trailer. not as in batmobile.
If you don't have anything nice to say....
NachtBlau coupe is my favorite color
pj said:Bert where were you on sat you missed a good one.
chicane said:TodB said:Ah, Mr. Chicane with the quick (and negative) reply. Right on cue. Michael meant BAT as in Bring A Trailer. not as in batmobile.
Now how would you know that is what he meant?
Bill Riblett said:I saw this car at Hershey last October. Here is what the owner put on a sign about his car:
"This 1972 BMW 3.0 CSI has been completely restored and, in all outward appearances, retains the repidly appreciating Hofmeister classic looks. It has been a California car since the late 70s. Elegant nachtblau (night blue) metallic paint with a redone tan leather interior and carpet. The expansive wood trim is perfect. The steering wheel is a very rare optional sport wheel (verified by included period accessory catalog). Period Becker Europa radio is improved with recessed package-tray-mounted new version speakers. I have installed new seals in the power sunroof. The trunk mounted drop-down tool ket is 100% complete even including the “BMW” blue cloth! Now for the icing on the cake … the mechanicals!! Fully updated drivetrain with 3.5 liter motor, Motronic fuel injection, overdrive 5-speed and differential, completely rebuilt of course, with less than 2,000 miles on motor. Not only are all clutch, cooling, brakes and suspension parts new but all hardware has been painstakingly upgraded and replaced! The underside of this vehicle, from the polished oil pan (!!), the ultra-rare NOS front underbody shield, handcrafted exhaust system, custom heat shields and the incredible attention to detail are a sight to behold! To retain the original D-Jetronic Injection System appearance, the modern Motronic airflow meter was ingeniously mounted inside the stock air cleaner with the new air cleaner assembly carefully concealed behind the right headlamp. Even the speedometer, stock in it appearance, has been upgraded to electronic to read off the differential sensor. Several thousand dollars alone were used to upgrade the air conditioning system with rotary compressor, larger capacity BMW “5” series electric auxiliary fan and controls. Vintage Alpina 16” 20 spoke alloys, cross-drilled rotors, urethane bushings, Bilstein shocks, fornt and rear custom stress bars (rear bar contains battery mount, hidden by a custom-trim pull-down blind which finished the trunk compartment), and high performance 225/50R16 tires included."
At that time, he was asking $39,900.
It is a CSi, the VIN is 2265279.
It is pretty and the injection system conversion was cleverly done. First impression was that the car is somewhat over-restored, but that was mostly all the stuff under the hood that was finished nicer than when it was new.
This particular CSi did not have a sunroof originally so another sunroof equipped roof was grafted into the roof pillars.
sfdon said:Has anyone else noticed this car is advertised as Motronic but what I see is a Jetronic distributor cap. What's that about??
pj said:I would like you to buy my coupe at THAT price.
