Honolulu
Today I got back into the CS after several months not driving it. The plan was to get the carbs tweaked, because the car idles a little roughly, and softly pops out the exhaust pipe at idle. To me this suggested the idle was way rich.
Once the flow was equalized at idle, I found that manually tweaking the accelerator pump lever on the front carb sped up the engine, while doing it to the rear carb made it bog. Condition filed for reference, since I wanted to get at the richness first.
I went to the idle mix screws. Running in (leaning) the idle screw on the front carb eliminated the soft popping out the exhaust, but all the way in, and the speed didn't change. Also, the screw on the front carb didn't run it to a stop, it just got tighter and tighter. Running in the idle mix screw on the back carb had the expected result, speed dropped and engine died.
Removed idle mix screws completely and noted they are hollow on their long axis, end to end. There is a hole all the way down the long axis you can see through. They also have two radial drillings to the side of the jet.
Took a pair off my "other" set of carbs, and they were not drilled completely through the long axis. WHICH SET IS CORRECT? I can't imagine why one set is drilled all the way through...? I don't think "outside" air is intended to be mixed/metered into the idle circuit by these screws, and thus the "spare" set are proper.
Any thoughts welcomed. The suspect idle screws were from a Karzunparts kit for Zeniths, sourced long ago.
