Latest activity
  • Pittraider18
    Pittraider18 reacted to dang's post in the thread Fender rolling with Like Like.
    I feel fortunate that a good friend of mine has retired from painting cars for 35 years and is using my paint garage to do odd jobs. He...
  • nealf
    nealf replied to the thread Trans rebuilder wanted.
    Yes that would be great thanks. I had the replacement shipped from MN in a tupperware, and the one in need now resides in the...
  • sfdon
    Using a car cover for a car that’s gonna be in the rain a lot is really just a decision to ruin the water base Paint..
  • sfdon
    sfdon replied to the thread Trans rebuilder wanted.
    Trannies get shipped in Home Depot plastic bins for pretty cheap across country Pete at Petes gear Shop still does some Trannies for...
  • adawil2002
    adawil2002 replied to the thread DIY - Heater Bypass Valve.
    I like that idea, mine is a solenoid powered by a yellow lighted push-button switch next to the rear window de-fog switch.
  • sfdon
    sfdon reacted to nealf's post in the thread Trans rebuilder wanted with Like Like.
    Trying to revive this thread and revive a 5 speed trans that needs rebuilding preferrably the closer to Philadelphia, PA the better. Thanks,
  • sfdon
    sfdon reacted to Arde's post in the thread Trans rebuilder wanted with Like Like.
    Probably not, bad bearing symptom is grinding regular noise when transmission is in idle that goes away pressing the clutch.
  • sfdon
    sfdon reacted to adawil2002's post in the thread DIY - Heater Bypass Valve with Like Like.
    I'm all for the heater bypass solenoid. Not being one to do it myself when it comes to the combination of plumbing & electrical, I let...
  • adawil2002
    the coupe had been sitting for around 25 years when we purchased…I see a few changes.
  • ScottAndrews
    ScottAndrews replied to the thread DIY - Heater Bypass Valve.
    Been through this thread a bit. I like the simplicity of the OG approach using the vacuum actuated Delco valve (although I like the hose...
  • mkekiddoc
    mkekiddoc reacted to Mike Goble's post in the thread 1973 hot rod CS on BaT with Haha Haha.
    "The 15″ BBS RX224 wheels are mounted with 226/60 Kumho tires." 225, 226 - whatever it takes...
  • sfdon
    The things that aren’t being shown or talked about…. Fenders replaced.. shoddy bondo filling in fender drain holes… If the fenders had...
  • Minivansomeren
    I drove it up the ski area road (not where the pic is) to 9300’ and it ran fine. But I also live at 7000’ normally. I just got the car...
  • nealf
  • vince
    First couple of pictures don't do it justice. I liked it more as I went through the pictures, usually the other way around.
