Latest activity
  • TomHom
    ... some more parts
  • Breiti
    Breiti reacted to e9Leveque's post in the thread Thoughts on engine removal with Like Like.
    First coats went on well - primer and topcoats tomorrow after sanding and tacking!
  • Breiti
    Breiti replied to the thread BMW e9 upgrade.
    Put some red Koni at all 4 corners, close the valves 1 and a half up too 2 revs. Rebuild your steering to zero tolerance. You will...
  • Breiti
    Breiti reacted to ScottAndrews's post in the thread BMW e9 upgrade with Like Like.
    I’d stick with an M30 based engine (M90/M30B35, etc). Go for a Getrag 265/6 overdrive trans. There are various suspension kits. I went...
  • e9Leveque
    e9Leveque reacted to ScottAndrews's post in the thread Thoughts on engine removal with Like Like.
    LOOKING GOOD!!!
  • ScottAndrews
    ScottAndrews replied to the thread BMW e9 upgrade.
    I’d study what the group 4 cats had then
  • M
    Mark9299 replied to the thread BMW e9 upgrade.
    I know it’s very complicated to swap suspension and there’s a lot of custom modifications that needs to be done. That’s why I’d rather...
  • ScottAndrews
    Ok. You’re on. Where do I send the plane ticket!!:p
  • ScottAndrews
    ScottAndrews reacted to boonies's post in the thread 72 3.0 CS 2240344 Restoration with Like Like.
    Going back in is surprisingly easy with everything clean and no extra parts in the way. An extra set of hands will go a long way. Have...
  • ScottAndrews
    Your car, but my experience is the M90 has more than enough torque to pull a 265/6 with 3.07 diff. The CRtrans will limit your top end...
  • M
    I was thinking of putting m90 engine paired with Getrag 265/5 close ratio and rear differential 3.07 side loader with limited slip. I...
  • Minivansomeren
    Minivansomeren replied to the thread Baikal 72 on BAT.
    Sure the paint is beautiful, but without the sticker underneath, it is very obvious that the grilles are just cosmetic. At least with a...
  • rsporsche
    rsporsche replied to the thread Front Seat Removal.
    there are many different products to coat leather with and the finish varies greatly. in simple terms, there are 2 basic types - one is...
  • ScottAndrews
  • sfdon
    sfdon reacted to e9Leveque's post in the thread Thoughts on engine removal with Like Like.
