Latest activity
  • rsporsche
    rsporsche replied to the thread 72 3.0 CS 2240344 Restoration.
    i was thinking about leaving everything connected to the fuse box and all the relays / switches
  • rsporsche
    rsporsche reacted to ScottAndrews's post in the thread 72 3.0 CS 2240344 Restoration with Like Like.
    OK, having some phun now!!! Got all the wires out of the car with the exception of a wire that goes through a separate firewall...
  • e9Leveque
    e9Leveque replied to the thread 72 3.0 CS 2240344 Restoration.
    One option to consider - I decided as I was rewiring to make some items a bit modular to allow easier revision/repair later. For example...
  • vince
    vince reacted to Stan's post in the thread BimmerLife with Like Like.
    If anyone gets BimmerLife you will see the article about The Great White. Pictures turned out good too.
  • K
    Koopman replied to the thread WTB 1973 e9 trunk catch.
    Can I have a photo please. Thanks
  • ScottAndrews
    It was actually easier to go the other way. Once the wiring under the dash was all disconnected from the fuse box and a couple of spade...
  • ScottAndrews
  • e9Leveque
    @sfdon what's the cost for those bows? And to what do they bolt onto - looks like they sit above the pipes holding the heat shield up?
  • Markos
    Markos reacted to Stevehose's post in the thread It's time to sell my E9 with Like Like.
    Thanks Chris, you have summed up my feelings exactly, it’s not only the car but the people we meet which explains the bittersweet aspect...
  • grnder95
    Hello, I'm in need of the trunk catch in decent working order for my coupe hopefully US based. Thank You in advance
  • ScottAndrews
    It does make sense as a modification to the existing harness. it is, however, not very space efficient. I did locate the seat belt...
  • sfdon
    sfdon replied to the thread tranny tunnel thermal insulation.
    I have a limited amount of the Bows that hold the heat shield above the Center muffler onto the pipes available that I had made part...
  • sfdon
    sfdon reacted to rsporsche's post in the thread tranny tunnel thermal insulation with Like Like.
    i have been planning to do something for a heat shield above the exhaust, just haven't got there yet. will probably do that when we do...
  • sfdon
    sfdon replied to the thread need a starter.
    "Taping up" a non fused wire that goes directly to your coil and next to your ignition switch and letting it hang in your engine bay is...
  • D
    DaveBeddows replied to the thread need a starter.
    The stock wiring provides a ballast resistor bypass during the starting process. The theory is that the electrical current pull from...
