Latest activity
  • rsporsche
    rsporsche replied to the thread 72 CSi wiring diagram.
    on the taillight, if the ground is there and good - check the wires around the light switch and hazard relay + switch. perhaps there is...
  • ScottAndrews
    ScottAndrews reacted to e9Leveque's post in the thread My BMW journey has begun with Like Like.
    I would tell you that it’s worth it to do the mechanical parts now and get them as good as you can, the interior can always be done at a...
  • rsporsche
    there are grounds all over the car. all solid brown wires are grounds. brown wires with a color stripe generally has a circuit that...
  • ScottAndrews
    ScottAndrews replied to the thread E9 A/C Condensate Drain.
    Yeah when those concours judges start removing the evaporator to confirm you have the correct drain you are going to be sorry...
  • ScottAndrews
    ScottAndrews reacted to rsporsche's post in the thread E9 A/C Condensate Drain with Like Like.
    since i was going to enlarge the hole anyway. i think i am going to enlarge it a little more and put the e24 drain in it ... since a...
  • rsporsche
    rsporsche replied to the thread E9 A/C Condensate Drain.
  • bluecoupe30!
    bluecoupe30! reacted to rsporsche's post in the thread My BMW journey has begun with Like Like.
    not sure i completely agree with you about being able to fix things without recovering. i had cracks in my upper dash that i carved...
  • bluecoupe30!
    bluecoupe30! reacted to e9Leveque's post in the thread My BMW journey has begun with Like Like.
    This can be a bit challenging. I completely disassembled my underdash segments / glovebox and fusebox and stripped them, glued the Foam...
  • ScottAndrews
    ScottAndrews replied to the thread 72 CSi wiring diagram.
    In the regular Cs diagram you can locate the tail lamp wire and start diagnosing. Which part of the tail light causes the fault? There...
  • C
    Chris Reber replied to the thread 72 CSi wiring diagram.
    I did manage to find a color diagram for a CS on an older thread. Hopefully that will help me out. I'm basically going through the...
  • C
    Chris Reber reacted to Dlc's post in the thread 72 CSi wiring diagram with Like Like.
    https://e9coupe.com/forum/media/categories/chassis-electrical.49/ https://e9coupe.com/forum/media/74-3-0cs-wiring-diagram-png.4626/...
  • Wobdog
    Wobdog posted the thread Polish Chrome bumper in E9 Discussion.
    My bumpers look good overall but have small scratches in them. What products, methods do you recommend to get them out and leave the...
  • ScottAndrews
    ScottAndrews replied to the thread My BMW journey has begun.
    Not sure. I suspect they re-flocked it since they tend toward the concours end of things.
  • ScottAndrews
    You will want the funnel to pass through the hole into the trans tunnel, then seal around it, or put some sealant on the lower end, and...
  • ScottAndrews
    foam donut was long gone on my car. i will put a bead of sealant around the opening when installing.
