Latest activity
  • sfdon
    sfdon replied to the thread 72 CSi wiring.
    That double black wire comes from your ignition switch to that spade connector and then goes to your diagnostic plug. It is the crank...
  • C
    Chris Reber reacted to HB Chris's post in the thread 72 CSi wiring with Like Like.
    A ground wire is never black they are always brown. If near the starter it may come from the 12:00 terminal and is hot when cranking...
  • sfdon
    sfdon reacted to Chris Reber's post in the thread 72 CSi wiring with Like Like.
    Hi all, Found this little guy dangling near the starter. 2 Black wires crimped together, possible ground? Can't find his home plug...
  • sfdon
    sfdon replied to the thread 72 CSi wiring diagram.
    Don, your link above takes me to the United Arab Emirates Amazon site - you been ordering your straps from the Middle East these days...
  • e9Leveque
    e9Leveque replied to the thread Front speakers.
    Poking around a bit more, the GRS site (the guys who make the small planars I used) don’t show any other sizes. But PartsExpress has a...
  • C
    Chris Reber posted the thread 72 CSi wiring in E9 Discussion.
  • ScottAndrews
    ScottAndrews replied to the thread Front speakers.
    Aww c'mon man.. don't you want your car to look like this? :p I agree with you on most points. I am having those gaping holes welded...
  • ScottAndrews
    You're currently running some approximation of an "infinite baffle". The distance from the front of your speakers to the back is fairly...
  • sfdon
    I had only linked one LAN title but knew I’d seen others. Google AI solved it! When I searched “e9coupe.com LAN” to find another...
  • sfdon
    sfdon reacted to ScottAndrews's post in the thread 72 CSi wiring diagram with Like Like.
    US Amazon source...
  • sfdon
    sfdon reacted to e9Leveque's post in the thread 72 CSi wiring diagram with Haha Haha.
    I did use that Porsche number for the copper one, but had also previously ordered one similar to the Chumia one which I used else where...
  • e9Leveque
  • JMinPDX
    Well done. I’d forgotten some and some are new to me. I would add: IMHO - In My Humble Opinion or just IMO if you’re not inclined to...
  • e9Leveque
    With the limited space available behind the dash speakers then, what are the options for cabinet vs port? Scott, you had mentioned...
  • JMinPDX
    AAV = Auxillary Air Valve (D-Jet component) AFAIK = As Far As I Know AFR = Air Fuel Ratio AMP = Ampere BAT = Batmobile, Bring A Trailer...
