Latest activity
  • ScottAndrews
    ScottAndrews replied to the thread E9 A/C Condensate Drain.
    Closed cell foam... Ideally the drain pokes down below the edge of the tunnel, so the water "should" drip down without ever actually...
  • e9Leveque
    e9Leveque replied to the thread 72 3.0 CS 2240344 Restoration.
    The day you figure this out I see a run on those Porsche gauges on Ebay...
  • rsporsche
    rsporsche replied to the thread E9 A/C Condensate Drain.
    hi Chris, thanks, i already have one that @HB Chris sent me. perhaps somebody else might be in need ... or you might want to keep it...
  • ScottAndrews
    So yesterday I ordered a couple of other VDO gauges. I am hoping these can replace the wonky temp gauge I have been trying to retrofit...
  • sfdon
    sfdon replied to the thread Bmw alpina 14x7 ronal wheels.
    Long island NY
  • ScottAndrews
    Can you pull off that mounting plate and show us the under side? I believe there should be a foam "donut" that sits under it. The hole...
  • Ohmess
    Ohmess replied to the thread E9 A/C Condensate Drain.
    So, @rsporsche - I'm probably late to the party with this information, but truth be told I wasn't in any hurry to pull apart the dash of...
  • Ohmess
    Ohmess replied to the thread Program tester needed?.
    I too have a fuel pump switch. Trouble is, if my car has been run recently, it will start and run half a block on the fuel in the bowls.
  • e9Leveque
    e9Leveque reacted to Ohmess's post in the thread Program tester needed? with Sad Sad.
    Thread drift -- When I worked in DC, I would occassionally look out the window and see tow trucks dropping off cars on the streets...
  • restart
    restart replied to the thread Program tester needed?.
    I use a hidden fuel pump switch.. a thief wouldn’t get far. I use it when I’m working on the car and I need the ignition on without the...
  • restart
    restart reacted to Ohmess's post in the thread Program tester needed? with Wow Wow.
  • restart
    restart reacted to e9Leveque's post in the thread Program tester needed? with Like Like.
    Hadn't seen it either. @Stevehose something you'd be willing to post? While I understand the concern of someone using this info to...
  • restart
    Nice, hadn't seen that thread when I had searched for "program tester". I'm not sure that I saw the part number listed there but I...
  • Ohmess
  • StephenZ
    StephenZ replied to the thread WTB E3 left tail light lens.
    Yeah, I polished them up nicely, just the crazing remains....but it doesn't bother me enough yet...more important things to spend money...
