Latest activity
  • JMinPDX
    FYI Asking $155K Hope it finds a good home. https://www.hemmings.com/listing/1973-bmw-3-0cs-poulsbo-wa-768028
  • Ohmess
    Ohmess replied to the thread E9 A/C Condensate Drain.
    @ScottAndrews - here are a couple of pictures of the mounting plate unbolted and flipped up. It appears that the ring you mentioned...
  • rsporsche
    rsporsche replied to the thread 72 CSi wiring.
    David, what @e9Leveque has stated happens on both sides of the car. the one on the drivers side grounds the headlights, relays, turn signal
  • rsporsche
    rsporsche reacted to e9Leveque's post in the thread 72 CSi wiring with Like Like.
    I was just writing the same thing. This attaches to a screw on a panel next to the side marker behind the headlight. You're going to...
  • e9Leveque
    e9Leveque replied to the thread 72 CSi wiring.
  • rsporsche
    that one probably should be pulled back and accessible for a ground connection under the light access panel. that is probably one of...
  • A
    Acemechanic reacted to e9Leveque's post in the thread 1974 2002Tii FS on BaT with Haha Haha.
    Well, when one line item reads "no work completed on car this period" for a charge of $476, sounds like I'm not paying myself enough for...
  • C
    Chris Reber replied to the thread 72 CSi wiring.
    I found another loose ground wire group at the ignition coil. I'm assuming the body shop may have covered the original hole that it...
  • rsporsche
    i think they need the stella M1 in that lineup that a certain friend of ours has in his collection ... as well as the warhol M1
  • autokunst
    autokunst replied to the thread Copart BMW finds....
    I like that the listing reads "runs and drives". I'm sure it is true, but not legally on the street without tail lights. Am I an idiot...
  • S
    Wasn't certain where to post this, but considering the original "art" cars started with the E9. Here is an article from AutoWeek...
  • S
    stphers replied to the thread Carb question....
    yes
  • ScottAndrews
    That's what I originally thought, but it is indeed a moving iron type meter movement (a fixed coil with a mega net attached to the...
  • Sean Haas
    Sean Haas replied to the thread Carb question....
    I think the o-ring you are referring to is this one?
  • Sean Haas
    Good advice, the float part I did check for free motion but have not re-started after installing the new gasket. I recall seeing a pic...
