What are the Details in the Rear Fenders Between E9 and E120
Krzysztof
Poland
Does anyone have had a chance to compare rear fenders between E9 and E120 (2000c/cs)?
I know they are some but the question is how big they are and if the difference can be easily modified towards E9?
I was looking on many pictures and still have no clear understanding about the differences in shape, size etc.
Bob
Salinas
Contour of wheel arch on e9 thicker than 2000c/cs wheel arch thats about it.
Krzysztof
Poland
Indeed. That's why I have asked about some details as looking on the pictures might be misleading.
Many cars were repaired and who know when and what has been doing as most of these both models have had problems with similar places at the rear section.
Maybe someone did that comparison on physical parts having them at place?
Krzysztof
Poland
Thanks.
Have you been able to compare them in the reality or telling from the pictures?
I have look on many and on some at least the arch seems thicker for E9 but on the others looks similar.
What about the rear "pockets" under the bumper line or the sill trim area profile shape?
Bob
Salinas
Thanks.
I had a 2000cs now my brother owns it and Inhave a e9 I'd say identicle with much smaller wheel arch bulge on 2000cs. I always think a rear ended e9 could be pieced in with a 2000cs rear end and just use the wallothnesh wheel arch rust repair piece for the thicker wheel arch.
zinz
Austin, Texas
Are you wanting to cut panels off a 2000CS for use on an e9?
Here are pictures of my 2000CS as we repaired the rear wheel arches. Some trimming of the W&N e9 replacement panels was required (on the inside edge), but the lip is close to identical. We replaced similar sections on both sides of my car.
Ed Z
Krzysztof
Poland
Thanks for pictures,
Yes. It is much easier to but 2000cs body parts than pure E9 and knowing the rear part is almost identical
zinz
Austin, Texas
Be sure to measure the depth of the lip. I think you will find the 2000CS is more narrow (I had to trim my replacement panels) If you are going to use a 2000CS fender on an e9, you may have to grind down the e9 panel to blend where they meet. (I hope that is clear)
Ed
