davi duma
New Member
Hello, in need of small bracket, I believe 2 parts, that hold clutch slave cylinder in place for a 1972 Bavaria.
thanks for your time,
Dave
Dave
Thanks for responding. I have the cylinder with the supporting ring & clips. The picture on the bottom has bolt holes used to secure the cylinder directly to the block. What's missing in the pic is the bracket that holds the cylinder to the block...upper pic . .thanks again . . DaveDave,
do you have 4 speed or a 5 speed in the car? - it does make a difference. the upper slave is for the 4 speed / early e3 + e9 ... the lower slave is for the 5 speed / late e3 + e9
