CRJ Driver
CSI inc.
Don't these guys in the LA basin sell progressive springs?
Not initially. Not because of some intelligent cogent plan, rather many of the threads here did not mention them, Korman didn't say I needed them and I didn't think to get them. If it comes out silly will get a set for sure. Will post before/after pics hopefully.
uh oh... will find out this afternoon.are you running 16" staggered alpina wheels? if so, you might want to quickly reconsider - unless your fender lips are already rolled. you stand a high probability that you will catch a fender lip w/o the lips being rolled and/or w/o negative camber plates. i know from personal experience ... aaaargh
Thanks..and thanks very much to everyone else as well.Good luck this weekend!
be careful about speed bumps. that's what got my fender lip
while i believe, they are similar, i don't think they are exact - or made by the same people. that is a guess on my part ... i suspect they are each made by a company that has done work for the respective companies. Korman undoubtedly worked with some companies when racing. Carl Nelson probably found somebody in a similar manner. my understanding is that Korman uses the same company to make the sway bar and springs.
The longer the returning arm, the softer the bar for a given diameter of bar (i.e more leverage)
and the reverse is also true, short arm, the stiffer the bar.
Sure, but the torsion bar connects to another arm of the same length on the other side, don't the leverages then cancel each other?
