4310316 begins
aearch
pleasant hill , ca
yae ill have to break it in before i can dyno it
so THE UNIT WILL BEGIN ITS NEW LIFE ON THE FIRST FULL DAY OF SPRING
aearch
pleasant hill , ca
so irt seems lile the trunk springs wont work even after bending more tension in them
so i just overlapped them and no no problem
oh well need to keep the trunk up
if i took out the tools itd works ok but then again.
never know when you need them thats for sure
OCCoupe
Monterey, California
Alan, the spoiler is weighing it down. I know of some other coupes running the same spoiler and their trunks won't stay open. You'll need a prop.
aearch
pleasant hill , ca
so it seems the body shop didnt set the fender correctly
BUMMER
so when i get another 10K ILL HAVE THE FRONT REDONE
its to far in so the door wont align
so to compensate
i had to move in the upper hinge
but as most of you dont know there is a bent in bracket as a stop
so i had to grind it out to move the fender the needed 2mm/
go figure.
aearch
pleasant hill , ca
i received the sun visor from Scott
very happy with it -its 99.9% perfect
and the logo is in the center
as i mentioned i had one on my 2002
that came stock w/ the car.
aearch
pleasant hill , ca
its my original
sent it off to speedway and had to pester them to get it done then
they didnt send the center part.
too bad there the only game in town
another reason i had all my alum just polished
cheaper, faster and looks fantastic
aearch
pleasant hill , ca
day trippin
so off to the shop, anthony tried to dial it in yet the kdata unit was too undocumented so had no way of configuring the internal links.
also the brand new ox senser was no good
there goes a quick hundred. --- so in the last two yrs the tech has so greatly improved that my unit was obsolete -
and the new stand alones are literallly ten times more efficient and durable. and will provide even more power from the engine ----
go figure.
so im going shoppin in a minute.
all in all areal good day
it seems theres not much luck on the driver door -the pass side is perfect. --
so ill have to wing it as best i can.
the story continues.
aearch
pleasant hill , ca
thank you all
so the kdat ie megasquirt unit is outdated allready, so i need to get the "links storm" unit then
it WILL" be running next month
super busy tuners.
first time ive seen the car on the street, out of the grotto -(carport)
