I see that W and N have a drive shaft repair kit, ie rubber boot and grease etc on offer this week. What is the view in these vs the original rubber? Ie when repainting the rear subframe, changing dampers springs etc, is it worth changing these? Or, is the view that if they are not failed then leave alone as the OE will be better and last longer?
Is it possible to remove these boots, clean and degrease the joints and replace the same boot?
Thanks for your views
C
C
