Momo Ruspa wood steering wheel
craterface
Sanibel Island
This came on my old coupe. The wood is a pretty close match to the door wood. 35cm, fine for cars with power steering, not recommended for manual steering cars. Provides more knee room than the bus wheel for those with long legs.
The mounting hub is included. Can someone tell me if the hub also fits a 2002?
$125 plus shipping from 33957
if you look in the coupe registry for 2240442 you can see my old coupe with the wheel installed. Just click the link for the gallery.
yes and no. yes it will fit (the splines are the same), but the horn contact arrangement is reversed in a 2002. The hub houses the spring-loaded contact for the 2002 whereas the brass ring is on the coupe's hub. It is possible to modified the hubs -aka, switch parts- to fit E9 hubs in 02s and etc.
