Hi. I need to remove the outer spacer from my front hub for better wheel fitment. Do I simply pry them off or is there more to it, e.g. shorter lug bolts?
I moved my front tires closer to the center of the car by milling 3/16” off the backsides of the wheels, then I had to trim all the wheel studs the same amount so it was a lot of work for very little gain.
The size and offset of your wheels is fine....what you need are camber plates at the top of the struts to "lean" the wheel and tire in more.
I might try this (in unison with lowering springs to reduce top-of-tire-wheel-well height).
