Ah...slightly errant start on this thread.
I grabbed deQuincey's graphic which did a great job of identifying the clearances on his coupe.
And....although there was a similar thread on ground plane to trim line, it posed too many variables..tire / rim size, air pressure etc. etc.
So...this was to be a reference point for a new thread which used the centerline of wheel to underside of wheel arch lid for lowering height comparison which should be more consistent and reduce the variables.
I am 90% thru an install of Hardy and Beck's lowering kit which includes their springs and specially valved Bilsteins (to the extent the rear shock is actually adapted from a 2002).
Much like the discussion on the CN springs, the amount of drop is not quite what was anticipated, so for a better understanding I am interested in reference points.
After the install the H&B setup looks as follows, all centerline of wheel to underside of lip:
LF = 14.5" / 368mm
LR = 13.5" / 343mm
RF 14.75" / 374mm
RR 13.625 / 374mm
The front does not have a camber adjustment plate (potential nominal additional height) and the rear uses the one dot perch rubber.
Now H&B says their set-up results in a 1 - 1 1/2" drop. For comparison these are the measurements on 40+ year old springs on the car before the install.
LF = 14.75" / 375mm
LR = 13.75" / 349mm
RF 15.00" / 380mm
RR 13.375 / 340mm
Have to expect sag over 40 years, how much? difficult to say, but would expect a lower stance.
Be interested in resurecting this data baseline information. Who knows it might inform future spring production getting us closer to where that visual sweet spot is.
John
