From the cylinder head cover there is a small hose connected to the original air filter.
I have weber carbs with their individual air filters. I had originally connected this hose to one of the carbs and found out that after a while there was oil collected in that carb. I disconnected this hose and replaced it with a longer one that now simply 'hangs' there.
Question, should/must this hose be connected to anything? Is the fact that oil was being collected (after a while) in the carburetor indicative of anything?
Fuel pump question.
I have a mechanical fuel pump. If I let the car 'sit' for a week or two it takes a while to start the car until gas is delivered to the carbs. Sometimes to the point it almost drains the battery.
I'm considering installing an electric fuel pump to deliver gas but still keep the mechanical fuel pump. To be clear, the electric fuel pump would deliver the gas to the mechanical fuel pump. Any problems with this set up?
Some may suggest to have only the electric fuel pump but then the mechanical pump would still be operating without fuel being there and would probably dry out the diaphragm.
Any thoughts?
Fuel pump question.
Any thoughts?
