sreams
For those of you who have the Carl Nelson springs, did you measure the effect lowering the car had on camber? I'm curious about how much negative camber would be added... in degrees.
Do Carl's fixed camber plates add positive camber to compensate, allowing for closer-to-stock camber? Or do they add even more negative camber? The ones from Ireland Engineering mention that they add negative camber.
I just received a set of the K-MAC adjustable camber plates from BavAuto. They seem to be very well made, but they only seem to allow for adjustment toward more positive camber. I was hoping to be able to set camber to about 0 degrees for normal driving, and push toward negative for track days. If lowering the car adds enough negative camber, these could work (thus my first question). Otherwise, it looks like I'd have to drill three new holes on each side of the car to flip the camber plates around, thus allowing for them to be adjusted for additional negative camber. I'd obviously like to avoid that option.
As a side note... if the K-MAC plates work out, they are a nice alternative to the stock strut bearings, since they are less expensive (oddly enough).
-Scott
-Scott
