Slave cylinder leaking
JD4020
Sarnia, Ontario
Not sure what transmission I have. These are the numbers I found on the side of transmission beside slave cylinder location
001563EM
240
262 051000
226 2.2
Can everybody tell me which manual 5 spd transmission I have. Thanks
And should I rebuild slave cylinder or just purchase new one?
The engine is a 1986 535i.
Thanks Larry
My Getrag 265 says
26205190 (the last two digits not relevant)
225 1.3
And looks like this. Buy a new slave.
Master and Slave Cylinder with hose
Master 21-52-1-156-000
Slave 21-52-1-116-300
Hose 21-52-1-153-512
for 1985-1986 535i or 1983-1984 533i
I ordered new slave cylinder.
Your new clutch master if you buy one will be oriented a bit to its side so just bend pipes or modify as needed. It's the only one available these days.
I've rebuilt both the clutch master and slave cylinders, quite easy if the inner sleeve is in decent shape.
