bosch microfiche projector
I am still getting odd equipment out from workshops around
it is a joy to restore them and to be able to use them, i know a PDF file Works much better, but,...i couldnt resist
i had to clean, fix the lenses, moving parts, build a new axis and support for the carrier, and now try to find a suitable fan to refrigerate the light box
if anyone knows a source or has microfiches of the e9 that will not use, please tell me about them
I have a working BMW factory projector and a set of BMW fische I'd like to part with.
Doug
I can check if Maxwell Smart has some microfiches to keep you busy.
Compromising pictures of Kaos agents in cheap bordellos perhaps?
I picked up the set of part books on microfiche a few years ago, I had a very hard time looking at them with a standard US-size reader. Finding that alone was difficult!
BMW fisches.
I have a complete set of all the BMW fisches gathering dust in the corner, as well as a BMW Minnox projector..
All the microfiche are coming out of the woodwork. I also have a small stack of fiche including E21, E24, E30, 32, 34, 36 and Z1. Anyone interested contact me.
DeQ, I suggest for a fan, simply use a small fan as used to cool your computer. I think maybe they run on 5 volts from the power supply, but this could be in error. They should be readily available at any shop that does repairs, or of course, on the 'net.
thanks for the tip
yes i willtry to find a 12 volts fan (typical in electronic applications) as the projector runs on 13,8 volts,
