Valve Cover needed
vslve cover
This the sort of thing you are after?
current valve cover
Here is a pic of the cover I am looking for
rocker cover
this is a standard CS valve cover - the CSi valve cover has the oil filler opening at the rear of the valve cover to be clear of the throttle body / air cleaner.
Er.... No. That one of for the later ljet E3s see below. Here is a 74 CSi one in situ with the oil filler at the front.
Still looking?
Missing stuff
Don, I'm looking for my red sled that says Rosebud on it - can you look and see if it is in that pile of parts?
I miss it dearly.
Thanks Don, yes I am. Seems like the one on top is a match but is that damage from the air box towards the right side? Thats what I have on mine. BTW, do you have a cooling tube for that engine as well? Mine is fairly corroded.
I'll send you a close up. I have quite a few valve covers.......
Coolant tubes are usually rotten. I'll check tomorrow.
Outside and inside pics
Hope this helps.
Oh well...try again
You ARE correct!
Duck egg Blue air filter cleaner?... The question is, does anybody have a CSi air cleaner bracket that they'll let me carefully cut off an inner fender?...
