So as part of my rear end rebuild I replaced all the rear wheel bearings (4)
Original bearings were open style that you pack with grease.
New bearings from BMW are sealed bearings.
So there is a spacer that goes inside the hub with a shim that you can order different thicknesses of.
This spacer I feel is designed for open packable bearing like original.
So again can I leave the item #6 & 7 out and not use at all?
Bearings are pressed in to internal stops and hub is secured with a nut so no way they can move around?
What does anyone else think?
Don, have you experienced this?
Can't seem to get list of parts to stay in format.
